+ Reply to Thread
Results 1 to 25 of 25
Thread: Tay Sport Muck Boot review
    Default Tay Sport Muck Boot review
    Well as you may have seen here I have upgraded my Avon Muck Boots to a pair of Tay Sports. Once again I went to Oakbury Welsh Cobs for both my initial research and eventually my order (see below for untangling the Muck Boot models). For the history of the Avon Muck Boots and my review of them see here. The general principals of why I prefer wellies as my outdoor footwear are covered there and apply to these boots just the same.
    Why Wellies?
    Lots of reasons. First the obvious, I want to keep my feet dry. Cold wet feet sap moral as well as being just plain uncomfortable. Wellies allow you to trudge through puddles, long wet grass and undergrowth while still keep your feet, as well as the bottom of your trousers, dry. For heather and heath country they are ideal. In these conditions normal boots are often fully immersed letting water in and soaking your socks.
    They allow me to wade out a bit when launching the canoe as well as letting me get out the canoe without having to ram the shore. So if nothing else I am extending the life of my canoe as it is getting more soft landings.
    Another benefit when camping is the ease with which you can take off and put on Wellington boots. When using a hammock this is a particularly welcome benefit. Swinging from a hammock and trying to undo laces and pull of a boot may not be a sport but it is at least an entertaining spectator event. With Wellingtons you can simply kick them off. When you wake and need to take that midnight pee the boots are easy to put on for the dash in the dark and simple to remove again when you get back. No more tripping over loose laces in the dark whilst both half asleep and with a full bladder adding a sense or urgency.
    Why Muck Boots?
    Simply because Muck Boots solve the problems that you usually get with wellies. What are the wellie problems? Cold, sweaty and uncomfortable.
    The Muck Boots are not only not cold but are in fact among the warmest boots I have ever used. They achieve this by a number of methods. They have a foam booty which insulates the foot area and also makes the boot buoyant. The upper is made from neoprene and has a liner, which varies with model.
    The inherent problems of getting sweaty feet while wearing an entirely waterproof knee length boot are dealt with by using a breathable, wicking liner. All explained in The Science Bit.
    Comfort is also a result of a number of factors. The rubber in the boot is natural rubber which is more supple that the normal TPR or PVC on cheaper boots. The foam liner also helps as does the lining of the boot upper. Together they give you a warm and comfortable boot that is a pleasure to wear. Of course do not take my word for it. Try a pair if you get the chance and see for yourself.
    Of course another reason for choosing Muck Boots is the quality of the construction. My Avons were well made and stood up well to the abuse I gave them. The Tay Sports are, if anything, better made and look like they will last even longer (NB my Avons are still going strong and currently been given a hard life by Driftwood)
    Harking back to my reasons for wellies the Muck Boots are specifically designed to be removed “hands free”. The quote the blurb “The 10mm kick rim or pull tab makes it easy to remove, while the sturdiness and stretch of the CR-foam bootie makes it easy to step into the shoe or boot without having to pull it on”. So easy to remove while swinging in the hammock
    Why change from the Avons?
    Good question. The Avons would have done me for a long time and performed well enough that I had no cause to complain about them, however, I am one of those people who is always looking for improvements, even if they are only slight. I think I like to strive for perfection; my wife calls it something else
    So given my obsession when I saw that Muck Boots had launched a range of extreme cold weather boots I was tempted right away. As I mention in the Avon review I tent to get cold feet. Paddling the canoe your feet are often in cold conditions and not being moved so not generating any heat. In these conditions it is not uncommon to get cold feet. Well I say not uncommon but it actually was uncommon in the Avons but it still occasionally happened in extreme conditions.
    So first and foremost my reason to upgrade was to see if they were warmer, while still not being sweaty. I was also not keen on the camouflage pattern. Whilst not an issue on most trips it was not ideal for walking the dog in the park or anywhere else where you get smart alec comments from passers by.
    I was interested to see how the “improved” tread would perform but this was not a major factor in the move.
    Was it Worth it?
    Yes but I suspect you want more detail than that.
    Let us start with warmth. The Tay Sport bots are definitely warmer than the Avons. Surprisingly this was very difficult to notice. Because of the breathability of the boots you feet do not get sweaty or uncomfortable so your do not feel too hot. They do not feel cold either so how do you tell if they are warmer?
    This took some time. I have used the new boots in a lot of conditions and never had cold feet. This could have been because of the improved insulation or it could have just been because it was not that cold. Eventually on a trip just after New Year we had a chance to compare. Russell (Warthog1981) was wearing his Avon Muck Boots and I was wearing the Tay Sport Muck Boots. It was a cold night and at one point Russell said his feet felt a little cold. My feet were still toasty warm in the Tay Sports and usually I would get cold feet before Russell so this would seem to prove the Tay Sports are indeed warmer. I have to point out that it was very cold and we were sitting around so in normal footwear we would both have had really cold feet much earlier on.
    The fleece lining of the boots not only helps the heat retention but also makes the boots more comfortable when you have bare feet. Now I do not make a practice of wearing the boots without socks but as they are so handy to put on when you need to go out and get coal for the fire or check the chickens in the morning, I do find myself wearing them barefoot relatively often. The Avons were comfortable enough but felt a little plasticy on bare skin. The Tay Sports feel, well, fleecy, which they are.
    I was concerned that the additional fleece lining would limit the ability to turn down the tops of the boots but this has not been the case.
    Turning down the tops of the bots in warm weather greatly increases the surface area available to wick away moisture and keeps the boots dry in the hottest conditions. If you have managed to get the boots wet inside (an unexpected swim from your canoe, surely not) then turning down the tops of the boots and wearing them till they dry is the quickest way to dry out the boot. The fleece lining will tend to hold the water a bit of it does not have the heat from your feet to evaporate it. Wringing out your socks periodically helps speed this up as well.
    The new tread is meant to be an anti clog pattern.
    From my use that is certainly the case. The mud etc I had been stomping through just prior to the taking of the picture would have filled the tread of any other boot or show I own, including the Avons. I have yet to even partially clog the sole. This makes the boots ideal in muddy conditions as you retain your grip and the boot does not get heavier as you carry increasingly large amounts of mud about on your feet.
    The comfort of the Tay Sport is at least a match for the Avon and still far and away better than any other Wellingtons I have tried. When I go on a trip I have only the Muck Boots as footwear. They do me while canoeing, round camp and for the late night toilet trip. Now this is not just an exercise in multi function weight saving. It is because for my use the Muck Boots are the best option for use in the canoe, as a camp boot and for the midnight dash.
    So the Tay Sports have all the benefits of the Avons and perform better in some of the most important areas. So as I said, yes the change was worth it.
    Are there drawbacks?
    Again, yes, after all you can’t have everything.
    The soles do not clog but they are not as grippy on slippy rocks or sheet ice. This is just the rules of the game. The solution to one problem compromises the performance somewhere else. Given that most of these boots will be used in muddy or snowy conditions the anti clog option is probably the better option. For use in ice the recommended solution is to use a set of YakTrax Pro. Not sure if these would help on slippy rocks but it might be worth checking for scrambling round rivers.
    Like the Avons the Tay Sport are not the first choice for swimming in but my footwear for canoeing is not chosen for swimming. If I have fallen in I have greater concerns than my swimming speed. What would be a greater concern would be if you could not swim in the boots at all. Thankfully you can. In fact as they are buoyant they are actually quite good for rivers where you should always keep your feet up to minimise the risk of your feet getting trapped. Also thanks to the “hands free” removal you can kick the boots off while in the water if you really do not want them on.
    The lug at the back is great for the hands free removal but can be an issue if you paddle from a kneeling thwart. This could catch on the thwart. I do not kneel very often in the canoe and when I do I am not using a kneeling thwart so not concerned about entrapment but it may be an issue for you.
    The Tay Sport boots are probably marginally heavier than the Avons, which themselves are heavier than walking boots. Of course comparing wellies to walking boots is not a fair comparison. Comparisons to walking boots and gaiters would probably be fairer and in this case I do not think the weight difference would be that much.
    Muck Boots are not cheap but even this is hard to be sure about. Sure there are cheaper wellies available but these are frankly not in the same class as the Muck Boots. I have heard of other boots that are able to compete with Muck Boots but these are in the same price range as the Muck Boots so for what you get the Muck Boots are, to my mind at least, great value.
    The Science Bit
    So if the boots are impervious to water how do they let the sweat from your feet get out? Lets have a look at the structure of the walls of the boots.
    Lets look closer still
    The fleece liner is at the top of the picture. The moist air from your foot can easily pass through this. It then passes into the void in the orange layer. Here the heat naturally takes the moisture up and out of the boot. Thanks to the neoprene and the foam boot the outside edge of the orange layer is not cold so no condensation takes place, at least not enough to be noticed.
    As well as allowing the moist air to pass through the fleece layer actually wicks moisture away from the socks or feet helping to keep your feet drier.
    Does it work?
    Absolutely. It worked well on the Avons without the fleece layer and it is better still on the Tay Sport. Whether the weather is warm or cold, wet or dry with a pair of Tay Sports your feet will not know what the conditions are. They will be warm and dry.
    When is a Tay Sport not a Tay Sport
    Now much as I like Muck boot as a company they are not going out of their way to make the models easy to understand. So here is a quick pointer about the nearly Tay Sport options. The Arctic Sport is the same as the Tay Sport but is in black (the Tay Sport being in green). The Spey is the same again but this time in camouflage. The Tay is NOT the same as the Tay Sport. It is very similar but it lack the fleece liner and is more akin to the Avon but with the new tread style and the rubber comes higher up the leg. I suspect the Torray is the same as the Tay Sport but with full camouflage but I can’t be sure of this as I did not ask for this to be confirmed, I was getting confused enough already.
    Conclusion
    Well if you can’t tell by now that I love the Tay Sport Muck Boots you have not been reading very closely. They are not the perfect boot but I doubt any boot every will be. The perfect boot would be very close to the Tay Sport but it would be light as a feather and the sole would stick like glue to slippy rocks and ice. Still if any company is going to make such a boot my money is on it being the Muck Boot company because if they have not revolutionised the comfort and usability of wellies in general then they have at least done so for me.
    So for the moment my search for my ideal Wellington is over. Of course I have spotted The Lune, a short boot by the Muck Boot company and can see times where it might be useful so my Muck Boot collection may not be complete yet.
    So for those skipping to the end. Highly recommended.
    Last edited by MagiKelly; 25th-February-2008 at 11:29 AM. Reason: spolling mistooks
    Song of the Paddle (Now on Twitter)
    Default Obese clown shoes
    I agree they are very warm but the size 6 on someone only 5'4 tall (me) look silly. I know this isn't about fashion but what you gain in warmth you also gain in VERY BULKY heavy boots. I guess for guy's they look in perfect proportion but I feel silly wearing them (ok yes I will just have to suffer slightly colder feet for the time being).
    <<<< Am prepared to be hated by the SOTP hardcore members now as I know how much Muckboots are virtually part of the uniform. Sorry guy's but if I'd ordered them online from the reviews on here rather than going to a shop, which luckily I did first and saw them, I would have been very disappointed by the way they looked and down £60 or more.
    Yes ok vain cow, but I'm sure I'm not the only one who doesn't want to walk round with obese clown shoes on my feet. ok maybe I am lol
    The size 5 in riding muckboots are lovely not bulky at all so what happens when they reach a 6?
    I have the opposite problem. Being tall I could do with the boots being longer. I could buy waders but that would be going to extremes
    West Country
    Good review MK
    I just wanted to add a personal endorsement for the fantastic Muck Boot.
    Just spent 3 days in mine on the Wye, only removing them at bedtime!
    My feet stayed warm and toasty the whole time, even after wading through
    ice to get into the canoe. Top boots
    Oh I forgot to add Russell's handy hint. Wear all wool socks and you should not have any problems with smelly feet, well not as many problems
    MK
    Shame they couldn't shave some off mine and stick the extra bits onto yours. perfect
    I am sure we could. A roll of Duct Tape should make it easy. Nice custom title by the way
    West Country
    Lou
    How come you didn't go for a pair like these?...
    http://www.muckbootcompany.com/produ...products_id=43
    much shorter
    Shropshire
    OK Magikelly you can stop now I'm convinced!
    But unfortunately I want the Arctic Sport-the black ones.
    So I did a bit of ferreting around on eBay and found a seller in the States who sells them for $109.95 + $29.95 postage = $139.90. That's just over £71 at the moment, I think.
    The seller's shop is called katahdintrailsaddlery 100% positive feedback but not a lot of sales so far. . .
    I'll keep you posted.
    There seems to be a strange set up with distributors. They do not all seem to be able to get all the models and to confuse things further they use different names for some of the models in different countries.
    I would worry that ordering from abroad you might get hit for import duty and VAT. Might be worth calling Oakbury to see if they can source any Arctics. If not there must be a UK source somewhere.
    Shropshire
    Too late for that I'm afraid!
    It' not the length, that was fine. It's the bulkyness of the foot especially the bulbus toes. They're not especially wide on the inside but if you look at them from the outside it looks like I could fit two of my feet side by side in one foot (well nearly) . Dont get me wrong I know they are really warm and almost perfect for winter paddling, I just wish, with todays technology they could make them less bulkily footed <<< Special Lou words
    St Andrews
    At the of veering sideways off topic, although it's related.
    Did you see this, John?
    http://www.safetyplusequine.com/fen-...pany-561-p.asp
    Which looks like an applied extension to muck boots, to allow for forays into the depths...
    They look pretty clumsy in the pix, (some of the worst ad. pix I've seen for boots/waders) but if the copy's accurate they could certainly have some application for folks like me who suffer the double maladies of and ?
    That shall float upon the river,
    Like a yellow leaf in Autumn
    Droitwich Spa
    Default Muck Boots
    All I can say is their the best things I have ever put on my feet, absolutely love 'em
    To travel alone is a risky business, especially in the wilderness; equally risky is to have dreams and not follow them.
    Quote Originally Posted by GoneFishing View Post
    I have not seen those before. it is hard to tell if they are permanently attached. If not how is the join made waterproof?
    St Andrews
    I emailed them this morning to ask for some clarification. It could be that they'd be just the job for me at times. That said, "ordinary" neoprene thigh waders are available for a fraction of the £90-odd they want, but I doubt they'd be as cosy as the MBCo's boots. (Having used ordinary Hunter-type wellies for yonks I'm pretty much sold on the Avons' comfort)
    I did check the Muck Boot Company's own site and didn't see a mention of this wader, so wonder if it's a mod that this UK company's carrying out under their own steam??
    Horror of horrors I ripped my Tay Sport Muck Boots yesterday on a nail sticking out of a log I was sitting on . It did not go all the way through and I made a temporary repair with duct tape. I should be able to make a permanent repair with a bit of rubber and some hot glue but I think I will still buy a new pair.
    I think I have said before that even if I only got a year out my muck boots it would still be money well spent for the comfort they give.
    Atlantic Canada
    Would a neoprene repair kit work on them? Angela looked them over very close before going to the bean boot and they looked pretty neoprene like at least?
    Lloyd - Now with 85% less surliness!
    Probably. Russell make a pretty good repair to his when he got a tare in it so I will ask him what he did.
    Carmarthen
    I mended the wifes horsey muck boots with Aquasure,.a few months ago it has stood the test of time.
    reassuringly negative
    Ahh that was the problem John, you should have been sitting in your boat rather than a log, canoes paddle a lot faster
    But Aquasure maybe the answer to your repair job
    Cheers Graeme
    SWWC the way forward
    Always sad to see a grown man cry I must say you were remarkably calm about it, I'd have been a little more upset than you seemed to be ie
    Here's hoping the repair goes well!
    Braintree, Essex
    Quote Originally Posted by Chainsaw View Post
    was this the kind of reaction you were expecting? (sorry for the hijack)
    YouTube - Simpsons - Homer Gets a Nail Through His Foot[/URL]
    SF Peterborough 14'
    weighs 7 Stone! 44.5kg
    Bell Chestnut Prsopector (so light)
    Mar 2007
    Musselburgh, Scotland
    John,
    We use this stuff at work for repairing our wetsuits - it's really good!
    George
    Smile - it makes them wonder what you've been up to!
    Courtesy of Yorkshire canoes i got some Aquasure and have glued the tear. looks like it has worked but I need to test it once fully dry. it looks a bit rough as the patch i was putting over the top only really took to rubber part of the tear.
    Will post pictures and the results when i get a chance.
+ Reply to Thread
