Thread: Anti-Drip Double Blade Paddle
    Hunter Lake, Minnesota, USA
    Default Anti-Drip Double Blade Paddle
    Has anyone every used a double blade paddle like this? The notches are supposed to prevent drips:
    The perfect canoe -
    Like a leaf on the water
    No, never seen that before. Wonder if it works?
    "So put me on a highway, and show me a sign..."
    I like that idea.
    It uses the properties of water and gravity to solve the problem of water flowing down the shaft. So much neater than the rubber rings one usually sees around the shaft.
    near Newcastle
    The paddle I used with my sit on top had two little notches, one on each blade.
    not the same as Pierre's notches obviously;
    but apparently designed to stop drips too.
    I've no idea how much difference the notches made in comparison to other paddles but I always got soaked from drips.
    I like the look of those wooden paddles
    cheers
    Steve
    Treat the earth well.
    We do not inherit the Earth from our Ancestors, we borrow it from our Children.
    Quote Originally Posted by rancid badger View Post
    Steve
    I think the problem with your paddle comes from where the shaft enters the blade and the tapered ridge that this creates thus preventing some of the water reaching the lower edge of the blade and the drip notch. The natural end destination of this water that runs along the ridge is the point where the black bit meets the grey bit and I bet that is where the drips form or the water runs down the shaft.
