+ Reply to Thread
Thread: recycling plastic bottles-lot of pictures
    just west of Newcastle, Tyne&Wear UK
    Default recycling plastic bottles-lot of pictures
    I put this together as a tutorial post on BCUK and just thought some of you on here might be interested.
    This, is a minnow bottle or if you prefer; a tree sap collector, either way it takes about 30 minutes or less to make and is a great way to recycle plastic drinks bottles.
    The raw materials: 2x 2litres drinks bottles.
    You need a pair of sharp scissors, in this case the one's on my 15 year old Gerber multi-tool.
    Some cordage,
    Something to make holes with, that doesn't mind being heated up and something to make the heat, in this case, a mini trangia burner.
    I started by cutting the top of one bottle,
    ending up with this:
    and the bottom off the other bottle:
    Then,after removing the cap from the cut off top, fit this inside the other bottle. It should look something like This:
    Next, you need to heat up what ever your going to use to make the holes. I used a home made awl, normally used for bark container making etc so not going to be ruined by heating.
    I have used a mini trangia in this tutorial as thats what i had handy, but you could use anything including the cooker if you wish. It's very difficult to see, but it's alight here!
    Once you have the awl or w.h.y. hot, start melting holes around the rim, about 15mm from the cut edge of the outer bottle.It pays to do one hole one side, then do the next one opposite. The holes being melted through, welds the plastic, helping to give the whole thing a bit of strength.
    Continue around the bottle, alternating as you go, till you have about 15-20mm between the holes.Then put your burner out! Your bottle should now look like this:
    Trim off the edges till you have about 15mm from the edge to the holes.:
    It's just a matter of "sewing" the two parts together now. You can use any cordage you have available:
    Here; we have spruce root on the left and Wych elm bark on the right:
    I decided to strip down some old terylene rope, just to give the job a totally "recycled" flavour
    Simply thread the cord through the first hole and tie it off-in this case; a round turn and two half hitches:
    then, just keep threading the cord through the holes;
    Until you get back to where you started:
    Then form a loop and attach a length of cord, long enough to allow you to cast the bottle to where your minnows are and...well......Robert's your mothers brother
    To use it; fill the bottle with water, add a few small bits of bread and then cast it into the area where your minnows are swimming. It also helps to chuck a few extra bits of bread around the bottle to attract the minnows to the area.
    You need to keep an eye on it as it can fill rapidly with minnows and once in, they can't get out! When you want a minnow for bait, simply unscrew the cap and let one out. You can refill the bottle with fresh water every half hour or so and you can also carry the bottle if your moving around.If your static; just leave the bottle in the water and If your boat fishing, you can simply hang it over the side of the boat, either way, the minnows get a constant supply of fresh water.
    So; there you go, if you need live bait for fishing, have a go at this.
    You can also use the same device for collecting tree sap; simply hang it on the spile and place a piece of cloth in the neck to filter out muck and insects etc.
    Even if you don't fish or collect tree sap, it make's a handy "pee bottle" for chaps in hammocks!
    Have fun and mind your fingers
    Steve
    If you don't do Anything!, You'll never make mistakes!
    I can see this being a good project for the girls to make and then test out. Thanks.
    Song of the Paddle (Now on Twitter)
    Feb 2006
    Glasgowish
    Default Another Use
    Another excellent use for these - smear jam around the inward-pointing neck of the inner bottle, and fill the bottom bottle 2/3 full with sugary water or flat lemonade. (You may wish to make them up from just one bottle, by inverting the top of a bottle into its own base, so it stands up on its own.)
    Either way, the perfect wasp trap for those summer BBQs!!
    The Canoeist's prayer: "Lord grant me the serenity to walk the portages I must, The courage to run the rapids I can, And the wisdom to know the difference".
    John Muir Trust - Wild Places for Nature & People.
    Thumbs up
    Quote Originally Posted by Blutack View Post
    Very clever I like that idea, although my style of barbecuing, generally leads to enough smoke to require wasps, flies and low flying aircraft to engage either radar or telepathy to see where they're going
    Yet another use for the tutorial bottle, is as a water filter, if filled with alternating layers of clean sand and crushed charcoal with either cloth or grass in the top bit to take out the big stuff and a tiny hole in the cap on the bottom.
    not as good as a real filter but better than a sock or trouser leg!
    Quote Originally Posted by MagiKelly View Post
    Your welcome, you can do all sorts with plastic bottles, it's such a shame there are so many lying or floating around. A small variation is to use the bottle material itself as cordage to "sew"it together. Just cut a thin strip around the rim, spiraling round till you have enough for the job in hand.
    Oh lordy, I'm not really a complete plastic bottle anorak-honest-
    best wishes
    Steve
    May 2006
    Atlantic Canada
    I do a project with old bottles to get the kiddies thinking safety. It works great for what it is. Basically a easy throw line that the even a 5 year old can make with supervision. It took a bit of hammering on SOTP but still, the whole idea is to get the wee ones thinking safety and used to the idea of bringing a throw line. That said it still works a treat and is pretty accurate, and mostly free.
    http://www.songofthepaddle.co.uk/for...ead.php?t=6452
    Lloyd - Now with 85% less surliness!
    North Staffordshire
    Mrs J classes herself as one of the 'girls' and doesn't want to make one!
    What do you suggest MagiKelly?
    Jamatrad
    Work like you don't need the money, love like you've never been hurt and dance like you do when nobody's watching.
    www.poetrypoem.com/jamatrad
    To start is but the beginning.
    Default Plastic Bottles
    What cracking idea's, must confess not a good recycle'r but I do like the ones portrayed. Happy paddling and recycling I guess Bill
    Quote Originally Posted by Jamatrad View Post
    I'd go for the throw bottle then
    Co Antrim, Northern Ireland
    Default Recycling ... not
    It's not recycling in the strictest sense of the word.
    Closer to reuse.
    May 2008
    Just North of Portsmouth. "Over the hill".
    What an ingenious thing! Top marks!
    Can I offer a little word of warning though. You must use this type of fish trap responsibly and tether it well. If you loose this in the water it will carry on relentlessly trapping fish for ever more.
    For that reason it might be better to use some form of quickly biodegradeable string to sew the two halves together, that way if it does get lost it will soon fall apart and become relatively harmless trash instead of a relentless trap.
    Who's been sleeping in my porridge???
+ Reply to Thread
