Results 1 to 23 of 23
Thread: Extending thule square bars
    Aug 2018
    Devon
    Default Extending thule square bars
    hi all,
    I have perused all the threads on extending roof bars so 2 canoes can sit side by side, and the best solution for temporarily but sturdily extending thule square bars seems to be adding some box section steel to each side - 4 sections in all?
    Either extending by sliding the box section inside the square bar, or outside the square bar and bolting together
    Just wondering if anyone has successfully done this and what size and length box section you used and fixing method worked best for you?
    thanks!
    Jan 2010
    Merthyr Tydfil South Wales
    I have done it on other manufacturers square / rectangular bars. mine was an external sleeve, the important dimension being the vertical one where it has to be an interference fit. width isn't as important they are fixed by a single 6mm bolt and nylock horizontally through the bar and extension piece. I have some photos inf you pm me with an email address.
    Southport, really in Lancashire, UK
    Chris_B may have an answer for that. Chris has looked into this sort of thing from and insurance point of view. But in the mean time we have to consider the insurance situation. An improvised adaption, although secure in our eyes may have bad implications in the event of an accident.
    You can buy Thule square bars in various lengths. You need to check that slots match your car. Thule Pro bars have slots on their full length.
    In the past I have used 50mm x 50mm timber bars to the width required strapped to the roof bars, they worked for carrying 2 and even 3 canoes. Although now I wouldn't recommend it.
    Carried over 200 miles like this.
    Doug
    When there's trouble on shore, there's peace on the wave,
    Afloat in the White Canoe.
    Alan Sullivan
    Aug 2018
    Devon
    Quote Originally Posted by nantcoly View Post
    will pm you thankyou!
    Aug 2018
    Devon
    Quote Originally Posted by dougoutcanoe View Post
    Doug
    well thats the thing i guess - in an event of an accident to have an unapproved modification or whatever the terminology is would not be great
    the alternative is get some thule probars - they arent cheap and also i'd have to fit them solely for when i want to carry 2 canoes on a motorway/long trip, i'm happy to carry 2 boats for local journeys using the one canoe flat/one canoe angled up method - leaving on the long bars isnt practical for day to day car use, and changing the bars is a bit of a faff...
    I have longer bars that I bolt on top of the standard ones. They are easy to remove and fit using cap head bolts and nyloc nuts. Very sturdy.
    The bars are narrower than my wing mirrors, but wide enough for two canoes.
    [/URL]
    The heads of the bolts are inside the top bar so don't interfere with loading the canoes.
    [/URL]
    The bolts are easily fittted using an allen key and ratchet spanner. The rubber spacers stay on the bolts when the extension bars are removed.
    [/URL]
    I do pretty much what Big Al does except I have the square head bolts that slide into the channel in the lower bars. I would strongly recommend using two long bars fitted on top of your narrow bars rather than trying to add 4 short extensions as the failure points are far less and the loads on the joints far less.
    When strapping the canoes on I always make sure than on the inside at least the straps go under both bars so that the original bar mounts would need to fail for the canoes to be able to come off.
    I use a (I think) 25mm square steel from B&Q fixed to the top of the roof bar with exhaust pipe clamps. It means I am not drilling anything to make it weaker. I cut the bar to the width of the wing mirrors, about 6 feet and use pipe lagging to protect the ends and reduce sliding. I've done several 1500mile journeys like this without problem. There appears to be no flex.
    Modifying the roof bars could be a problem with insurance etc. but Adrian's solution I'm sure would be viewed as part of the load, not part of the roof rack.
    My reccommendation would be to think in terms of something that straps/ties onto the roof rack which is in itself stable as a load. If your bar positions are fixed, you might add one or more longitudinals to ensure that the transverse bars cannot slip off the roof bars, but do watch out for roof curvature which causes the bars to not be parallel. If your roof bars end up in a different position each time you fit them, fixing longitudinals will be more challenging. Also watch out for the total weight creeping up - the weight of the roof bars themselves detract from the weight of load available.
    Leeds
    I have recently created a roof rack extension by securing t section aluminium bars 2 1/2 inch x 2 1/2 inch x quarter inch thick to the underside of my roof bars using M8 U Bolts
    Zoelzer bars (https://www.whetmanequipment.com/roof-racks.html) are then secured to the T sections using M8 t nuts supplied by zoelzer
    This helps to keep the bars parallel to each other and allows me to posission them anywhere on the roof not being restricted to the length of the roof rails
    In time I make a post about constructing this right but I've still got the part of it to build positioning a roler extension mounted to the rear bar.
    Sent from my SM-G950F using Tapatalk
    Leeds
    Zoelzer bars are also available in lengths to suit 2 boats and they make a version to fit Thule roof bar feet
    Aug 2018
    Devon
    thanks very much everyone for your advice and solutions !
    ok so I can see that a single bar over the top of the short bar makes sense, and i like the u-bolt / clamp fixing idea, super easy to get off and no drilling...
    so 25x25x3mm box section , 3m length x 2 is about 40 online , cut to required length also
    galvanised version - about 60
    Just noticed thule do a square bar @ 2m , with the plastic sleeve - 90
    Leeds
    I have found that the originally titled u bolts R Us supplier very useful
    https://u-bolts-r-us.co.uk/
    Nov 2017
    Aldershot
    Quote Originally Posted by WaterHarmonics View Post
    That's expensive, 7.5/7.6m length is around 20-00 inc Vat
    https://www.fhbrundle.co.uk/products..._6m_Grade_S235
    Aug 2018
    Devon
    indeed! thanks for the link
    Aug 2018
    Devon
    Quote Originally Posted by E_McNeill View Post
    Ewan, what internal diameter u bolt did you use that fits nicely like that around a thule square bar? 30mm?
    Derby England
    Ewan, did you check the weight of all the various bits a pieces? Probably ok but you might be close to exceeding the load rating of your bars / rails on your car? Also consider that with the overhang you won't be distributing the weight evenly between the front and back bars
    Leeds
    U-Bolt M8 x40 mm Thread, 32 mm Inside Diam, 61 mm Inside Height T316 Stainless Steel
    Used with
    Slotted backing plate for M8 U-bolt (22 - 36 mm ID) T316 Stainless Steel
    And extra penny washers
    They are a very good fit round Thule bars
    https://u246613.ct.sendgrid.net/mpss...S7JlS3s3mJg-3D
    P.s yes checked weight
    I've yet to make an additional modification to redistribute the wait support more evenly
    Aug 2018
    Devon
    great thanks
    KI metals on ebay are pretty cheap too, wasnt that keen on getting a 7.5m length of bar
    https://www.ebay.co.uk/itm/MILD-STEE...T1gL-6oSjezNBA
    Aug 2018
    Devon
    I ended up getting a pair of thule square bars 200cm on sale, and securing them on top of the permanently mounted square bars with u-bolts. Quick and easy to put on and off and very solid. The ubolts ewan recommended above are just the right size
    Very happy with this arrangment!
    I was away when this thread started and missed it, but I see dougoutcanoe mentioned I might have some thoughts. My old car had a square bar rack made when the feet wrapped around the bars, without slots, so I was able to fit longer Thule bars directly. I replaced it in 2015 and went for Thule ProBars, which have full length slots and are available up to 2m long.
    So far as insurance is concerned, most require you to inform them if you modify the car. Some insurers consider fitting any kind of roof rack as a modification, and since you have to tell them about it, I think they'd expect you tell them about mods to the rack too. Others say a roof rack is an accessory, not a mod, and don't need to know. Typically, their attitude is that if it's easily removable (and leaves no trace) it's an accessory, if it's fixed to the car it's a modification. They usually expect you to follow the makers instructions when fitting and using the rack, which is one reason I always tie the boat ends down to the towing points - it's in the instructions. So if the instructions say "Do not modify the rack", you could invalidate your insurance if you do. Depending on the way you modify it, you may be able to say the extended bars are part of the load. Personally, I wouldn't hide anything from the insurer, the potential consequences of not being covered are too high.
    Whether you modify your rack or not, it's worth checking whether your insurer expects you to tell them you use a roof rack - otherwise, they can invalidate the policy when you claim (even if the claim is nothing to do with the rack).
    Aug 2006
    I take it you saw the thread I did about 9 years ago on this. http://www.songofthepaddle.co.uk/for...-Standard-Bars
    I found this the simplest method a they just sit over and round the existing bar using 2x1 box section.
