Results 1 to 7 of 7
Thread: Side mounted mast?
  1. Default Side mounted mast?
    I read an article and can't seem to find it anymore.
    It talked about mounting the mast on the side of the boat instead of the center.
    Does anyone know the technical name of this style, so I can do some research on it ?
    Carl
    Ft. Worth, Tx
    The technical name is "bizarre". Sorry, I couldn't resist.
    On a small narrow boat I wouldn't like it due to the problems sheeting in the sail properly and supporting the mast well.
    Should work much better centered.
    I don't know an actual technical name.
    Marc
    The only craft I know with a single none central mast is a Proa, but you area heading down a whole complex but very interesting design route with that
    https://tinkboats.wordpress.com
    http://proasail.blogspot.co.uk
    What I get up to
    https://youtu.be/X9NZEyvpb_Y Streaker dinghy
    https://youtu.be/oni-3rJzxqQ Sail Canoe
    https://youtu.be/eW078PPgJak Proa
    There is a view that proas are symmetrical, just not about the usual axis, this the mast is indeed on the Centreline.....
    Quote Originally Posted by DougR View Post
    True, in a pure mathematical definition of symmetry the hull of a proa does indeed have an axis of symmetry. However with the rig in its usual position it looses the symmetry but that is just splitting hairs.
    What I get up to
    Feb 2011
    Devon ..just up from the bottom and right a bit.
    Google bought me here...https://sailstrait.wordpress.com/other-boats/.
    It was really bugging me as I discussed offset mast a few years ago and I can't remember the details...
    Dec 2012
    Pennsylavania USA and Ontario Canada
    Default Side mounted Masdt: Bolger Brick
    Phil Bolger's BRICK sailboat (precursor to the PDRacer) uses a side mounted mast. There has been a lot of discussion on that, Bolger arguing that small asymmetries go unnoticed in sailing. Side mounted leeboards have the same kind of offset.
    http://carlsondesign.com/projects/bolger-brick/
    Search a bit....
    Bob
