Thread: Solway Dory Sailing Canoe
    Nr Watton, Norfolk, UK
    Default Solway Dory Sailing Canoe
    Solway Dory Sailing Canoe for sale
    16 ft plywood construction sailing canoe by Solway Dory.
    Comes complete with SD 44 sq.ft. Bermudan sail, a set of SD outriggers, paddle and trolley.
    Can be used without the outriggers.
    Everything is in very good condition, but has had little use over the last 2 years due to other commitments.
    This will need to be collected from Norfolk (near Swaffham), so if it is a long journey, why not plan to collect then head on to the Norfolk Broads for a sail as well?
    Priced at 800 ovno, and happy to discuss the most effective means of payment.
    Let me know if you want any more photos. More photos at http://www.ocsg.org.uk/marketplace/
    Thanks for looking.
    Attachment 2076
    Attached Images Attached Images
    Apr 2018
    Fife and Ardnamurchan
    Is this the Avocet model kitetraveller?
    With thanks
    David
    Life is short and responsibility overrated - John Gierach
    Hi Fatshark,
    Apologies, I don't remember the boat type, but its not an Avocet, as far as I remember.
    Quote Originally Posted by fatshark View Post
    With thanks
    grange over sands, cumbria
    That is a plywood open canoe that we called Sunart. At 38 inch beam it is very stable for sailing and with the outriggers and rig is a very good value entry level sailing canoe. It is no longer a model that is available on the website as grp models took over. An Avocet would be the nearest equivalent model.
    Thank you Dave for the details!
    If I remember correctly, this was Jan's boat for some time as well?
    Quote Originally Posted by DaveS View Post
