Results 1 to 13 of 13
Thread: Mountain Bike Wheels
    Feb 2010
    Wetherby
    Default Mountain Bike Wheels
    I know nothing about bikes. I don't like them and don't ride them, but:
    My son had the back wheel of his Specialized Hard Rock disc stolen. I'm not sure of the year of the bike, but I guess around 2010. All I know is that it is a 26" wheel, and the original wheel came from AlexRims. Are any of you experts able to tell me what I should be buying to replace it.
    I know I need a wheel, a brake disc, a gear set, a tyre and an inner tube but have little idea of what they should be. I could go to my local bike shop, but living in Yorkshire the land of MAMIL I know I will get the most expensive version of everything.
    I've done much internet trawling, and frankly I don't understand the language used on the biking website. They have the same sort of codes that we do.
    Any help gratefully accepted.
    David.
    "Oh, Eeyore, you are wet!" said Piglet, feeling him.Eeyore shook himself, and asked somebody to explain to Piglet what happened when you had been inside a river for quite a long time.
    Well, the wheel, tyre and tube size will be the same as the front wheel. (Assuming he still has that - strange that they only took the back one.) So you can get the sizes from that.
    As for the gear cassette and brake disc, I'd ask a bike shop to fit these.
    Here comes the future and you can't run from it
    If you've got a blacklist I want to be on it
    Amsterdam, Netherlands
    take a pic of the full bike, and one of the rear part where the wheel goes, that shows the brake and the gear shifter. take those to a good bike shop and tell them you want a wheel with brake disk and cassette (gears) that fits. specialized are a well know brand, any good shop should be able to help you. ask them for different options or go to different shops if you don't trust them to sell something reasonable.
    Feb 2018
    ditch crawling
    Here you go Tyro, Specialised dealer in Harrogate
    https://www.specializedconceptstore....rrogate-store/
    Feb 2010
    Wetherby
    Quote Originally Posted by Crow View Post
    The front one was chained to the bike, as should have been the back one. I'd already guessed the wheels were the same size, which is how I knew it was a 26 inch. I suppose I'll have to brave the cycle shop. Trouble is, it's always full of blokes in lycra tottering about on their cycling shoes and discussing their latest "three grand carbon" (whatever that means).
    Funnily enough, he now has my 25 year old Black Knight bike with him in Oxford, and he can leave it outside his house without it being bothered at all. Shame he seems unable to fix a puncture.
    Feb 2010
    Wetherby
    Quote Originally Posted by Ditch Crawler View Post
    Thanks, tried them. When asked, they didn't do spares, but were more than willing to sell me a new very expensive bike. I suspect I got the Saturday numpty when I went in. Perhaps a mid-week visit might give me more luck. Some of the wheels Specialized do sell are worth more than my car.
    You are going to need a wheel for disks similar to this one, a rotor, a rear cassette of some sort, tyre and tube and maybe some axle/skewer type stuff. Try going into the bike shop and saying, I know heehaw about bikes but this is what happened, how much to fix it....
    Maybe try these guys, they wont be the cheapest but they should be able to sort you out, even give them a quick call to chat, may help you decide if you want to make the trip.
    NotSoLittleChainsaw just got a new back rim from his local bike shop. He already had the tyre and cassette but got a new rim, spokes, hub and a new tube. Guy swapped all the bits from his old wheel onto the new one and replaced his V-brake pads and charged him 62 quid, he also got a cheeky service as he has a good relationship with his Local Bike Shop. You are going to be quite a bit more than that maybe 100 to 150....?
    Merlin cycles have always been good for wheels. You'll have to add the price of tyres and tubes of course.
    It would cost you 60 for this rear with disc hub; https://www.merlincycles.com/shimano...-26-54304.html
    That should be decent and they build them well, I've had a few off them over the years. If its just a run-around bike, though, not sure its worth that much?
    Unfortunately the really cheap stuff I can see after a quick search all seems to be rim-brake versions, not disc.
    Feb 2010
    Wetherby
    Quote Originally Posted by Chainsaw View Post
    Alan,
    Thanks, that looks like a good shop to try, and I drive past there regularly and didn't know they were there. It looks much less intimidating than my local shop.
    David.
    Feb 2010
    Wetherby
    Thanks Mal,
    Oddly enough, when I try to click through your link, I get a strange message about SotP using cookies, and a tiny code web reference: https://prf.hn/click/camref:1011l3rZ...-26-54304.html. which fails to load. If I copy the address and paste it directly into a web browser it opens. Never seen that before, must be a new "feature" in the forum software.
    According to google, a standard specialised hark rock disc brake model in 2010 had a SRAM PG-830, 8-speed, 11-32t casette and an AVID G2 160mm disc rotor. Disclaimer is all the below is based on this.
    So you need a 26" wheel with an 8-speed hub that takes a bolt on rotor. Could be as low as 30.
    If you want to go original, order a G2 cleansweep 160mm rotor and a PG-830 casette.
    But ok. Practicality.
    If I was getting a new one I'd go to taylor wheels in Germany.
    Wheel would be Mavic rim on deore hub for 48.66.
    https://www.taylor-wheels.com/bike-w...-fh-m525-black
    Super bargain shimano casette with new chain: https://www.taylor-wheels.com/bike-p...-cassette-hg41
    I'd get a replacement rotor off ebay:
    https://www.ebay.co.uk/itm/Avid-G2-C...UAAOSwT2pbLRL3
    You'll also need a quick release skewer, tube and tyre. Maybe a rim tape but most built wheels will come with them. If the front tyre is ok, get one the same.
    That's a realy nice, reliable setup. However it costs.
    Other option is second hand. Best place is if you have a local bike recycling place. Most towns now have one. Go in and ask. You need a 26" wheel, with an 8-speed 11-32t casette and a 160mm rotor. They are ususally charities and they get the stuff given to them. You could get totally sorted out for 30-40.
    I think I am probably too late to this, but if he is in Oxford then there are tons of 'normal' bike shops there, or he could go to Decathlon in Botley, they will sort him out without ripping him off.
    Feb 2010
    Wetherby
    Thanks for all the help. Following Stinkwheels advice and a revisit to Specialized, I've bought the bits, the wheels together and it slotted right in first time, and even all the gear intervals worked with no adjustments required. Specialized tried to confuse me by insisting that the gear cassette should be a six speed, but I bought the eight speed that I thought it should be and that proved correct. I have made a mild c***up, I've fitted a presto valve, where the other wheel has a schrader but I can live with that.
    Whilst refitting it, I discovered that the wheel thief had had to release the disc brake to get the wheel off, and the cable clamp was missing. An M6 bolt and a washer sorted that out. I had always assumed, that it was a quick opportunistic theft by someone just walking by. The fact that they had Allen keys with them makes me now think they were deliberately on the look out for bits to nick.
    On the being in Oxford thing, he currently has my very elderly mountain bike, which developed a puncture six months ago. Despite living on St Clements, he hasn't managed to take it the 100 yards to the very helpful bike shop on Cowley road to get it fixed yet.
