Results 1 to 17 of 17
Thread: Help making a paddle please
    Default Help making a paddle please
    I'm trying to make a traditional paddle for flat water use out of a single piece of wood. The problem I'm having is finding some suitable wood. Firstly, my internet research indicates that kiln dried wood is not suitable. Kiln dried wood seems feasible to source, naturally seasoned does not. Will kiln dried work as this seems to be what I can get? Secondly, what wood to use? This is my first go and I don't have a finely honed set of woodworking skills. Cedar gets mentioned often as an easy to work, light wood with medium strength. This sounds like it would suit me. This information is often on North American websites though and the cedar seems to be different species (e.g. Western Red Cedar) than we might get here. How can I tell what type of Cedar to get? Yellow Cedar is sold locally to me (Bristol, UK). Ash sounds harder to work than some, strong and heavy (for flat water I am not too worried about strength and would prefer an easier worked and lighter wood). Poplar has been mentioned but I have not seen it advertised by timber suppliers. Thanks in advance, Alex
    For the first messing about, almost anything will do. Go to your local Big Box DIY store or timber merchants and have a rummage through the stock to find a few bits that are knot-free and straight grained.
    It would be worth getting hold of the book “Canoe Paddles A Complete Guide to Making Your Own by Graham Warren”
    It gives lots of history of why paddle shapes are what they are, along with tables of off-sets and patterns
    Here's one I made from a piece of softwood, a couple of bits of edging-bead and a staircase spindle ripped in half.
    26055746_2045642245668632_2022796700806941203_n
    26055731_2045642269001963_1808997253735912174_n
    Timber was ripped to size using a handsaw, planned up with a No4 Bailey then glued together.
    I made a template for the blade from the book and took the shape of the handle from another paddle
    Rough shaping was done with a jigsaw and final shaping done with a plane, spokeshave and sandpaper.
    It's had one piss-coat and a further four coats of yacht varnish.
    Thanks bigyellowtractor. I guess its time to go and get a piece of timber and give it a go.
    I would also strongly advocate using western red cedar for its ease of working. I can get this at my local timber yard (Totton) but I would think many others stock it.
    I have made 6 or so paddles from it and all are still in good condition and going strong. The other advantage is that when finished the paddle is relatively light. My only caution would be if you are making a paddle for white water, in which case a stronger material would be advised.
    Thanks. I'll try Western Red Cedar if I can get it at an affordable price. The local timber merchant only sells it in 3m lengths for 67. A big investment for a first project that might go wrong!
    Cumbria, UK
    These people do UK grown red cedar.....or they did, anyway. They're down your end of the country...from my perspective anyway.
    https://co2timber.co.uk/
    AND they do air dried!
    https://co2timber.co.uk/airdried.php
    Thanks rbm. That's very useful.
    I've made a few wooden paddles:-
    1st one:- Went to local woodmerchant/diy shop or wherever and bought a single bit of pine.
    Made paddle shape copied off a friend's paddle that I liked.
    Result: Worked but lots of flex as the wood was probably less than 1" in thickness. Not easy to work and get a good finish. Heavy(ish)
    However: I learned an awful lot about making a paddle, cramping, glueing adze/spokeshave/draw knife etc., etc., and what shape was possible and what shapes gave the best weight/strength ratio.
    Next ones had laminated shafts with 'Basswood' (English = Lime) bought from a timber merchant. This is easy to do using the offcuts from when you cut the paddle blank out and makes the shaft much easier to shape, and is far stronger.
    Result: Almost perfect but wasn't quite as light as the Grey Owl paddle I'd bought.
    3rd Paddle:- Made from a length of 'Redwood' from a timber merchant. Learning from my last experience I used the waste cut-off from the shaft section and laminated the shaft section before I did any more work and also glued some cut-offs in the palm grip area so I had more timber to make a better grip.
    By now I'd learned how to sharpen a draw knife properly, bought a second hand planer etc.,
    Result. Perfection: (well almost because I've made a few more since), but it's extremely light and has lasted through many whitewater paddles and adventures.
    So go buy a cheap bit of wood and distinclty aim for the 1st attempt and treat it as a learning experience - that way you won't end up being frustrated and feeling despondent. And as a bonus your wood working skills will have gone up a notch or two - all for the cost of a bit of wood, glue and your time.
    Quote Originally Posted by David Perry View Post
    Most people struggle and get frustrated with woodwork due to blunt or poorly set up tools.
    Thanks David. Another vote for hone skills first and I didn't realise that Basswood was Lime.
    Cherry is also good. I didn't find ash too bad, it was a little harder but was ok to work with, very 'predictable' if that makes any sense....
    I’ve made two paddles for my kids both out of cherry which is fine to work with and a lovely colour and finish. I’ve got a large piece of cherry to make one for myself, just need motivation / time.
    Just get the book mentioned above, Watch the You Tube videos and Chechen the posts on the forum as everything you need is there.
    Lime is a European version of Basswood. Very similar but not the same species.
    Western red cedar is fairly readily available in the UK. I would ask for imported from north America rather than using UK grown - the grain is nowhere near as straight or compact as it seems to grow much faster here. A climate thing I suppose. Co2 certainly did imported WRC - they had a picture of my first cedar canvas on their customer project page at one time.
    Sharp tools will make all the difference to your project.
    Thanks very much for your help everyone.
    May 2006
    Eastern Canada
    I designed a recreational paddle that is regarded well in some circles and it is dead easy to make. I would use any piece of wood that is free provided it is at least 7 inches wide, 1 inch thick, and 4.5-5 feet long.
    If you want more info let me know, but basically you draw a 7 inch circle, turn that into a 16-18 inch triangle then add a shaft and a 3 inch circle at the top of that.
    They end up looking a bit like this and work in most conditions. It is my favorite design personally as it works without tiring me out in lake water and has enough width at the bottom to work in shallow moving water.
    Lloyd
    Sometimes you're the windshield, sometimes you're the bug...
    Thanks Lloyd. That looks very interesting. On another note, your post in the canoe reviews section on the NC SP3 Prospector 16 inspired me. I bought one last month and it is as good as you say. Thank you very much. Alex
    I like that Lloyd. Easy to make in different sizes / proportions for kids too.
