Results 1 to 17 of 17
Thread: cedar strip build as a plug?
    Default cedar strip build as a plug?
    I am considering making a couple of canoes and wondered if anyone could offer advice.
    Firstly will a cedar strip canoe end up lighter Than a normal plastic construction?
    I would like to build a cedar strip as a nice project and then a second composite one.
    I'm wondering if I can build the cedar strip and then use it as a plug to layup the composite one on?
    Perhaps it more sensible to go the whole hog and build a female mold for the compsite?
    I'm just trying to get a feel for the most sensible and efficient way to go about it?
    I make surfboards so have a bit of composites experience and I also have vacuum bagging equipment if that changes the thinking on the plug or mold decision.
    Any advice welcome.
    Oh and I don't plan on making more than one or maybe two composite boats.
    Mar 2009
    Enkhuizen
    [QUOTE=r896neo;645578]I am considering making a couple of canoes and wondered if anyone could offer advice.
    Depends on how you build the cedar strip canoe and what you mean with "plastic", as Kevlar, Carbon, Polyester, Vinylester, Epoxy et cetera are plastics too. If you mean plastics like Polyethylene and Royalex/T-Formex, than yes you can build a lighter canoe with cedar strip -- if you do it well...
    Yes, but
    Probably, because this is the usual way AFAIK.
    Dirk Barends
    Cumbria, UK
    A stripper can be used as a plug, yes. Although purpose made plugs will often be of heavier construction than anything intended for paddling so as to maintain the shape properly.
    you can then take a hull straight off the plug but you will end up with the nice surface on the inside. The outside will be as good as you can get it with finishing cloth, sanding, filling etc.
    as aid, it's normal to make a mould from the plug and take hulls from that. It just depends in how much work you want to do.
    this book's quite good on the subject: https://www.amazon.co.uk/Canoe-Kayak...Canoe+building
    Rather depends on the shape - any recurve on the ends and it'll never come off the plug. Tumblehome similar.
    Quote Originally Posted by Willpower View Post
    you need a 2 part mold for shapes with tumlbehome or recurved ends.
    Propper writing in English. How do you do that? with dyslexia, bad hand eye coordination, ect. and in a foreign language.
    Sorry for all the mistakes.
    And that would rather spoil the Cedarstrip canoe used as a plug!
    nope the boat can be 1 part no problem , the new build mold needs to ba a 2 part afair. like here on the right
    Yes that's true but I read the OP as suggesting laying up directly on the Cedarstrip.
    Thanks for the replies, seems like its not going to work well. Any ideas on the most efficient way to get a second composite canoe from a cedar strip hull? Both will likely be prospectors but I'm not fixed on that. Would a prospector type require a 2 part mold?
    Cumbria, UK
    Quote Originally Posted by r896neo View Post
    It depends on the shape of the hull. You have to imagine pulling the new hull,out of the mould. As long as the open side of the mould is wider than the inside then the hull will pull out. If thenhull curves inwards anywhere as you go towards the gunwales then you'll need a two part mould. You can't pull a wider but of hull through the narrower gap.
    even if you have a one part mould (and I have) you might still struggle. Polyester resin will shrink slightly whilst curing and sompull itself away from the mould. An epoxy resin will kit shrink (not enough to matter) and so be much harder to rlease from the mould. One way around this is to include a small hole in th bottom of the mould through which you can pump compressed air, or water, to force the hull away from the mould.
    Cheers, I suppose perhaps then that will factor into which design i go for. Thanks for your thoughts. Any other opinions or advice welcome.
    Cornwall
    I pulled multiple hulls with tumblehome from a mould that only a split for a couple of feet of each end.The hulls would not come out easily.Rather than using compressed air as Rob suggested I used water,I put a couple of wedges between the mould and the hull until I had a big enough gap to pour water in and literally 'floated' them out.
    Thanks, been looking at some Kevlar ones where the stem is left open and then closed after demolding. Seems like a possibility.
    Just got the easy task of deciding on which cedar strip to build now. That's going to be easy.....
    Barendrecht
    If you want tumblehome or recurved ends and do not want to make a two-part mold you might be to make a mold from just the hull part and build the "deck" (tumblehome and/or recurved ends) on top of that. For instance a strip of plywood (finished with glass and expoy) will make an easy tumblehome if you attach it stitch and glue style.
    I have never done it, but went a long way down the examination route before abandoning the idea... A split mold that pulls apart forewards and backwards just need a mid point "fence" built round your plug, so that the first half mould includes the upstand to form the joint. when its gone off, remove the temp "fence", trim the upstand to the right dimensions, lay up second half to include another up stand (wax the upstand so that it will separate). When it has all gone off, drill for fixing bolts, pull mould off each end. bolt up, lay up another hull inside. If you look at as many photos as you can find on Millbrook Boats, some show how this works for him, and he has some seriously "deformed" hull shapes that work with a two piece mould.
    Don't give up on your idea.
    A heavily tumble-homed boat can still be formed over a male plug (your cedar-strip hull) if you accept that you will have to split the ends, and finish the stems off the mold. And, if when planning your boat you plan for floatation tanks fore and aft you have the opportunity to engineer the structural loads from the outset, and hide the difficult to finish inner glass/epoxy work at the stems.
    Good luck with it!
    Trevor Paetkau
    Ashes Still Water Boats
    Canoe Plans | Custom Boats
  17. Default
    Glass your cedar hull and leave it on the form. Before finishing it off as a cedar canoe if it's not finished yet. ?That is when I would make a mould off it as being on the form it would be as stable as it can be. You could make a port starboard 2 piece mould which takes apart at the keel C/Line.If you shape surf boards than you should have a keen eye and steady hand. Plugs need to be just about 100% perfect no strike that my mentor Swore by 110% perfect.Yeah he is right too I know.Your average cedar stripper is not that perfect to begin with although some folk can build them to near plug perfection.To be honest just build a dedicated plug and mould.Not being nasty but it's a huge outlay of cash and time you can never recoup.If you have an outstanding design then commercial use may let it pay for itself and being lucky you may even make a few bucks too.I like older designs from Ruston , English and Gerrish.I ain't going to be buying originals too soon .What with import costs and the rarely of these classics but the lines and offsets are available through museums and other sources. I can do cedar strip copies of these easily and whilst they are not genuine wide plank or cedar canvas the lines can be close enough to make me happy.Don't give up on it though cause it's doable for sure.Keep us posted please.
    richie
