http://valkyriecraft.com/overview-of...vas-open-canoe
Cedar and Canvas Canoes
The classic Canadian canoe built entirely from timber and sheathed in canvas. Based on the traditional native American birch bark canoes and modified by European settlers to make a boat that is beautiful, robust and a pleasure to paddle.
Key Features
Shearwater 16
Length: 4.9m/ 16’2″ Beam: 85cm/ 33″ Weight: 30kg/ 70lb
This beautiful canoe is designed along the lines of the traditional ‘Prospector’ with a focus on an exceptional all-rounder. It is fitted out as a tandem boat but is light and manoeuvrable enough to be a very responsive solo boat.
Designed with a slight rocker, moderate hull curvature and graceful fore and aft profiles, it handles well across a range of conditions. Its hull shape provides excellent manoeuvrability, has good tracking characteristics and its profile provides minimal wind resistance. It has ample space for day gear and room enough for all the gear needed for extended touring.
Shearwater 14
Length: 4.35m/ 14’4″ Beam: 85cm/ 33″ Weight: 27kg/ 60lb
The Shearwater 14 is designed as a beautiful and responsive solo boat. It is fitted out as a tandem and will carry two, but is most suitable for one. The two seats provide good sitting positions for adjusting trim as conditions dictate.
Designed to combine the various elements of length, rocker and hull cross section and with low fore and aft profiles this boat handles beautifully. It has excellent manoeuvrability, holds a good line and has ample space for solo gear for extended touring, or for day kit and short expeditions for tandem paddlers…..For the solo canoeist this is the ideal boat.
