Thread: Windsurfer board as a stabilizer?
    Aug 2012
    France 87
    Default Windsurfer board as a stabilizer?
    I would like to try sailing a 16" canoe. I have an old plastic w/s board that I was given. I was wondering if this is something that would work. I can make all my stuff, and what I can't, I scrounge.
    MANGLING DONE HERE
    I suppose it will work if you can sort out a mounting beam so that it all is level. It will be a kind of "proa" so the board will be supportive on one tack and a counterweight on the other.
    Aug 2012
    France 87
    Thanks.
    I have a 8" x1" pine board to fix the two together. This will be the support for the mast over the canoe. Would the rudder be ok between the canoe and float? That way there would be least alteration to the canoe.
    MANGLING DONE HERE
    A rudder works best as far from the centre of rotation as possible. Where you are thinking may be too close. You could give it a try though - it might work well enough!
    Aug 2012
    France 87
    What I have in mind will look like something Robinson Crusoe would have made. Either that or Heath Robinson!
    I like the idea of something like a catemaran with the mast in the centre.
    MANGLING DONE HERE
    Jun 2012
    Montreal, QC, Canada
    I used an epoxy sailboard to make outriggers. I cut it in half lengthwise and then shortened both ends, and then set them on edge. See here:
    http://www.songofthepaddle.co.uk/for...igger-question
    There is a short video showing the very first test run.
