Results 1 to 12 of 12
Thread: Sailing Across The Wash
    Default Sailing Across The Wash
    Okay, just come off the phone with Steve (Nice chap that did the Caledonian Canal with us) and we are planning to sail the wash over the next two weeks.
    We plan to sail from the Skegness side down to Hunstanton/ Cromer, overnite in the tents/ Steve's camper van and sail back the next day. We can't be precise about dates because the weather will play a big part and we don't want to go out if the winds are above 8 to 10 mph.
    This trip will be open to competent canoe sailors who have reliable well tested canoes. Drysuits will be required and VHF radio's an advantage.
    We welcome others joining us, but we cannot take anyone without the proper equipment or with a canoe that appears to be incapable for such a crossing as we can't afford for things to go wrong 6-miles from the nearest shore. (The crossing is 12-miles wide) Please get in touch if you are unsure about your equipment/ canoe or sailing ability.
    Our plan is to pack everything we need in readiness and be at 24-hour notice, but it would be over two days either a Friday & Saturday or Saturday & Sunday. If anyone is interested in this, please get in touch. :-)
    Isle of Ely in the Land of the Big Skies
    Good luck with the trip!
    Myself and Tony Brooks (Sues Canoes) have been planning to paddle this, here's some info' that you probably already have, but just in case you haven't:
    'Tidal Havens of the Wash & Humber' by Henry Irving, an Imray publication, gives some very good (and essential ) information of the tidal streams in the Wash, more appropriate to us than the info on the usual charts.
    Our starting point would be on the Hunstanton side, but due to the tidal effect (and that we would be paddling) we would have to start down near Snettisham so we didn't end up in the North Sea before making Skegness.
    If you haven't read the above book here is an extract that is worth being aware of:
    'The Admiralty Tidal Stream Atlas NP 252 North Sea, Southern Portion is not only at to small a scale to be useful in this cruising ground, but it under reports the strengths of the streams in some instances to a dangerous extent'
    If the wind dies then you could end up paddling, and I reckoned we would have ended up paddling nearer 18 miles under paddle power due to the effects of tide.
    Just on a personal note, I'd insist on every member having a vhf radio in case you get separated out in the middle.
    All the above you have no doubt covered, I only mention so as to be on the safe side and to be of help.
    Best of luck and enjoy.
    Davy
    Thanks Davy. Next weekend there is a North Easterly wind forecast which would help to keep us away from the North Sea and then it's a case of timing your departure with the tides so that you are not being dragged out to sea. I was thinking about taking my electric outboard motor as a backup plan. This gives me about 45-minutes at full power or an hour and a half at half power, but lugging it around with the leisure battery is no fun. At full power, it will push me along quite well. See below.
    I could just stick it in a drybag and lash it up the front of the canoe. If the very worsed did happen, it's a plan B.
    Steve and I both have VHF radios and used them quite a bit in Scotland this year.
    I have sailed in The Wash before but stayed within a mile from the shore line and your right, the tidal currents can be strong, especially around Kings Lynn.
    I haven't read the book, so I'll look up a copy, and thanks for the advice.
    I am hoping that at least one other person comes as three is the minimum number ideally for any expedition. Two other people have contacted me already and expressed an interest.
    It should only take between 4 & 6-hours depending on the weather & tides.
    An excellent adventure chaps. I wish you all the best and look forward to a great blog.
    Here's Gavin's report of his recent crossing:
    Les was at the club where he gave me more advice about crossing the Wash and told me about his previous experience as a lifeboatman. We looked through the club telescope at Roaring Middle buoy (which looks like a lightship) in the far distance. Leaving as late as possible to give the wind a chance to die down a bit more, I departed at 5.15 pm and waved goodbye as I set sail into a grey and stormy looking sea. At least it wasnt raining. Sailing westward, I hoped to be swept by the ebbing tide to West North West to Roaring Middle, which would confirm my position, before turning North West to cross the Long Sand Bank near high water. Once in the Boston Deep Channel I could sail North East up the channel to find the entrance to Wainfleet Haven. Largish waves coming from the South hit Stacey side-on and sheets of spray flew across the foredeck from left to right. A couple of breaking waves tried to climb aboard but, with Stacey travelling at about 6 knots, the self bailer soon got rid of any water in the boat. I was glad Id not set sail in any windier conditions. I was relieved when I could finally see Roaring Middle. At least I knew where I was in the middle of the Wash. After passing the buoy I altered course to cross Long Sand.
    See CanoeSailor Blog.
    I'd not be averse to crossing the Wash sometime... but am unlikely to be able to make anytime this summer. A few thoughts though...
    First up, you're looking at a forecast of no more than a "Gentle Breeze"...
    3 Gentle breeze 12–19 km/h (3–5 m/s) 0.5–1 m Large wavelets. Crests begin to break; scattered whitecaps Leaves and small twigs constantly moving, light flags extended.
    That's great... but a gentle breeze from the NE would mean a "fetch" all the way to Scandinavia... and could mean some big swells... and if the tide was ebbing at 4 knots... I suspect conditions could get "interesting", especially over the shallows either side of the "Boston Deep".
    Even if the breeze came from the SW, the fetch would be well over 10 nm: enough to allow a significant swell to develop. I trust you'd avoid a flood tide over the shallows with a SW wind.
    Other, related thoughts....
    A predicted 10-12 mph "gentle breeze" could easily die into nothing... or could amount to nothing if the tide was sweeping you in the same direction (reducing the apparent wind). The ability to paddle the entire crossing in calm conditions would strike me as an essential pre-requisite.
    A tidal stream seeping you into a predicted 10-12 mph "gentle breeze" could increase the apparent wind significantly, and a predicted F3 could easily blow up into a squally "Fresh Breeze"... which could easily back / veer from the predicted direction: I'd not want to be heading out in a F3 with anyone who'd be out of their depth with a F5...
    5 Fresh breeze 29–38 km/h (8.1-10.6 m/s) 2–3 m Moderate waves of some length. Many whitecaps. Small amounts of spray. Branches of a moderate size move. Small trees in leaf begin to sway.
    A F5 would require reefing (so sails should have that option)... and would entail a very real possibility of swamping. In an open canoe, I'd be carrying a LOT of airbags: enough to make progress if swamped. I'd ideally have a self bailer.
    Beyond all of that, there's always the issue of rig failure. Paddling is one's back-up mode in the event of rig failure. For this scale of undertaking... those taking part really ought to be capable of coping by paddle in a squally F5 if setting off in a predicted F3. Rig failure shouldn't be grounds for a distress call on the VHF!
    The crossing strikes me as eminently viable... but as easily underestimated!
    Cumbria
    My electric outboard (a Min Kota ) - and most others I've seen are not for use on salt water. You'd need to check the manufacturer's specs.
    Good luck with your venture, Chris. I assume you will not be using outriggers of any sort? Let's hope you don't feel the need for them on the crossing... Having talked with Gavin about his experiences recently it is certainly a serious undertaking. My couple of days sailing with him on the Yorkshire coast was very educational for me about the nature and size of waves that can be encountered on the east coast - I've yet to put a video account together of those experiences but believe me it was rather exciting.
    Hi guys thanks for your thoughts. Steve was suggesting a night camping at one end or another, but I would rather leave the camping gear and sail as light as possible so if I do capsize, it's no big drama.
    I have sailed in the Med off the coast of Gibraltar and the currents there must be second to none, but you don't have sand/ mud banks to contend with.
    I won't attempt this crossing if I don't feel comfortable with the conditions and that includes driving to coast going on the water and coming straight back off it if I am not comfortable. There will always be another day to have another go. I only live 40-minutes drive away.
    Sue, the Watersnake motor I have with 34 lbs of thrust can handle salt water, but corrosion can become a problem and is not recommended if you want a long life from it, but using it in the case of an emergency, corrosion would not be a major concern. That said, I am tempted to leave it behind, go light and prepare to do a lot of paddling if necessary.
    Update. Having planned time off work to make this trip on Friday with Steve, which coinsides with neap tides, the XCweather forecast has just revised the conditions from 10-mph winds down to 2-mph winds!!!
    The currents in the wash will be many times stronger than the winds and it would be unwise to attempt a 12-mile crossing in light winds and strong tidal currents. We will probably still meet up at Hunstanton and have a paddle in any case. It will allow us to talk to members of the Hunstanton Sailing Club and get some more tips about making the trip another day.
    Of course the weather forecast could change again before Friday.
    Friday [...] coinsides with neap tides, the XCweather forecast has just revised the conditions from 10-mph winds down to 2-mph winds!!! [...] it would be unwise to attempt a 12-mile crossing in light winds and strong tidal currents.
    OK - Friday is 27th.. and POL says High Water Immingham is 11:22 gmt... so 12:22 bst... and with a 6.42m tide, that's just a day away from neaps. So far, so good! Checking Windguru... the swell looks as good as it's likely to get: 0.3m-0.4m (though probably amplified over the sandbanks).
    The tidal diamond on my Memory Map charts suggest the following for neaps at 5301'N, 025'E...
    • HW-4 (08:22) - 223 0.3 knots
    • HW-3 (09:22) - 213 0.8 knots
    • HW-2 (10:22) - 212 1.2 knots
    • HW-1 (11:22) - 212 1.0 knots
    • HW-0 (12:22) - 212 0.5 knots
    • HW+1 (13:22) - 182 0.1 knots
    • HW+2 (14:22) - 032 0.4 knots
    • HW+3 (15:22) - 035 0.9 knots
    • HW+4 (16:22) - 038 1.0 knots
    • HW+5 (17:22) - 037 0.8 knots
    Now the wind direction (on XC and Windguru) looks like starting SE and then backing around to the NE: starting across the tide... but then against the ebb in the afternoon - which will affect the sea state, but will also increase the apparent wind.
    Beyond all of that, the pressure looks like being high, and the conditions pretty fine: some local knowledge would be good, but I'd suggest there's a good chance of a sea breeze kicking in during the afternoon - if so, some idea of scale and likely direction would be good!
    The forecast might change a lot between now and Friday, but to me, these currently look like near-perfect conditions for a crossing of the Wash: the crossing would remain a serious undertaking... but I can't see that a forecast for more wind would be an improvement!
    I'd be aiming to leave well before HW, accepting that I'd get swept a little to the SW (towards Roaring Middle).... but aiming to be at Long Sand not too long after slack water (when there would be not much current, and plenty of depth) with a view to riding the ebb up the Boston Deep.
    The fun bit could be getting into Wainfleet Haven against the ebb tide: might be a case of bobbing around for a bit and waiting for the flood.. or getting a little muddy!
    Greg, this was pretty much our exact plan except 10mph winds would give us the power we need to make progress. Bobbing around becalmed in the middle of The Wash 6-miles from anywhere is far from ideal and the idea of paddling the whole trip is not my idea of a good time.
    We are still getting ready for some kind of sailing/ paddling this Friday, but unless we have some wind, I can't see it happening. Alternatively too much wind will not allow the trip to happen either. I have wanted to do The Wash for a few years now, but I won't take unnecessary risks.
    Steve and I have agreed to travel to the area, possibly get the canoes onto the water if conditions are borderline and see how we feel. If we both feel confident, we will set off, but if one of us isn't comfortable, we will probably just sail along the coast, pitch up among the dunes, get a few tents up and eat some hot food with a bottle of wine or a few beers!
