no pics available
Std Features: Bucket seat, footbrace, flotation tanks, bow & stern thwarts, three-way adjustable sliding seat
SPECS:
Length: 16'7"
Beam: 28" 28.5" (@ 4"Waterline)
Bow Height: 16"
Stern Height: 12.5"
Center Height:12.5"
WEIGHT:
Fiberglass 46lbs
Ultralight 36lbs
The Freedom is a Jensen designed solo canoe originally introduced as the ‘F1’. Clipper has reintroduced it to our line as the perfect ‘workout’ canoe. It is also well suited for amateur racing. For wilderness trippers this canoe is appropriate for lighter paddlers carrying loads between 100-200#
The Freedom has a shallow arch hull and soft chines, all adding up to great stability. This canoe tracks well and is easy to maneuver when leaned offside to execute a tight turn. The seat is adjustable to three different heights and also slides fore and aft for maximum versatility in various water conditions.
