Page 4 of 4 FirstFirst ... 234
Results 181 to 204 of 204
Thread: New Firebox
  1. #181
    The system won't let me PM you until I have made three posts. This is number 2.
  2. #182
    This post number threeeeeeeee.
  3. #183
    Banbury
    Very impressed with my firebox, thanks
    The top plate is good if you have a ghillie kettle as it funnels the heat (I think?) and will boil the water faster, I don't have a ghillie, so didn't bother
    Sent from my E6653 using Tapatalk
  4. #184
    Like Dave MP above me, I have to put three posts before I can send you a private message. This is number one! Sorry I feel like I am spamming this place.
  5. #185
    I first saw these fireboxes curtsey of Mr Fox over at the GBBG, I didnt have the money at first so I scrolled past, but now I do I think It will make a great addition to my kit. Number two (Please dont hate me!)
  6. #186
    I really do hope you still make these, I dont know anybody else that does anything similar. Threeee!
  7. #187
    Banbury
    He's still got some I think, but doesn't come on here that often, love mine, sid me well at the open canoe association weekend
  8. #188
    Cornwall
    Quote Originally Posted by 1jack1pike View Post
    I've dropped him a message on facebook for you.
  9. #189
    Pershore, Worcestershire, UK
    Firebox are still available though I am making them to order at the moment which means a lead time of 7 to 10 days.
    The large firebox measures 374 x 220 x 160mm and is made from 1.5mm stainless steel,
    Large firebox in 1.5mm stainless steel.................53.00 + UK postage = 63.50
    Large firebox in 1.5mm stainless with top plate....67.00 + UK postage = 77.50
    The small firebox measures 220 x 220 x 160mm and is made from 1.2mm stainless steel.
    Small firebox in 1.2mm stainless steel.................44.00 + UK postage = 54.50
    Small firebox in 1.2mm stainless with top plate....57.00 + UK postage = 67.50
    Jon.
    Selway Fisher Peterborough 15' - 21Kgs
    FU-BCU Level 2 (Owns a canoe and gets out there and enjoys themselves)
  10. #190
    Quote Originally Posted by jondavy View Post
    Jon.
    Hi Jon could you post a pic of the large one with top plate and also the small one with top plate so as to get an idea of size difference visually showing key design point might well buy one from you cheers
    Sent from my iPad using Tapatalk
  11. #191
    Exmouth, Devon, England
    Quote Originally Posted by Ripvanwinkle View Post
    It takes some imagination, but this post shows the cutting plan for the two sizes: http://www.songofthepaddle.co.uk/for...353#post440353
    I'm not sure whether Jon keeps boxes in stock to take photos, so maybe you could model the size from cardboard or wire to see the difference? In that post he says that it's just shorter - so I presume the same height and width.
    Hope that helps.
  12. #192
    Aug 2016
    South Luffenham, Rutland
    I have the large box on order, so will post pictures when it arrives.
    Welding and fabrication for forum members.
  13. #193
    Kettering Northamptonshire
    I have had a large firebox for a couple of years now but initially I cooled it down by dunking it in the river; this appears to have buckled every panel.
    It can take 20 minutes to force it all together so I now keep it assembled and store stuff inside it in transit.
    Is there a way to flatten all the panels or am I stuck with my rather wavy firebox?
    A ship should not ride on a single anchor, nor life on a single hope - Epictetus
  14. #194
    south doncaster
    ditto
    Quote Originally Posted by Patterdale Paddler View Post
    nature is m X-box
  15. #195
    Claxton
    Double ditto! Still love it though.
    The early bird may catch the worm... but the second mouse gets the cheese!
  16. #196
    Derbyshire
    Are you still doing the fireboxes JohnDavy? If you are I'd be interested in a large one with top plate. I've tried to PM you but your message box is full
  17. #197
    Hi everyone, sorry for the delay in responses, hadn't seen until now that my mailbox was full and hadn't been checking in regularly.
    dtalbot, yes I'm still doing the fireboxes but they are made to order at the moment so they take about 7 to 10 days, prices are still as above, I will PM you the details.
    broardsman, andym and patterdale paddler, I have found that if I need to straighten or adjust the panels a bit that gently bending them over a hard edge will help persuade the panels to straighten out, the trick is to bend it just a little (not try and fold it) and work either side of the area as well so as not to form a bend in one spot.
    Jon.
  18. #198
    broardsman, andym and patterdale paddler, I have found that if I need to straighten or adjust the panels a bit that gently bending them over a hard edge will help persuade the panels to straighten out, the trick is to bend it just a little (not try and fold it) and work either side of the area as well so as not to form a bend in one spot.Jon.
    Thanks Jon - will give it a go - totally love the firebox anyway - Dick
  19. #199
    Claxton
    Cheers. I've only really tried standing on it when its flat packed and it just laughed at me. I'll give your method a go.
    Robin
  20. #200
    Dec 2011
    Western Lake District
    I have used a rubber headed mallet to re-shape the panels. Not very subtle, but works.
    Death is natures way of telling you to slow down.
  21. #201
    Claxton
    I had some fun with the kids at the weekend baking garlic bread and pizza in the firebox.
    I put some charcoal briquettes underneath a piece of cardboard wrapped in tin foil and then put more on the top plate.
    Worked really well!
  22. #202
    Oh that looks sooo good!
  23. #203
    The new small fireboxes are available now,
    Shown below is the standard large firebox with top plate next to a small firebox,
    Large firebox, custom firebox (I can make them any size) and small firebox with top plate
    I currently have in stock,
    1 x small firebox without top plate (1.2mm)
    4 x small fireboxes with top plates (1.2mm)
    1 x large firebox without top plate (1.5mm)
    I have another two of the large fireboxes with top plates which are due in on the 20th.
    Jon.
    Hi Jon what size is that custom one ☝️ thanks
  24. #204
    Are fireboxes still being made? I'd want a Large firebox in 1.5mm stainless steel, hopefully the list of people after them isn't too long and won't have to wait in line for months. By the way, could it be delivered by parcel abc? I've used them a couple times without a hitch, so would have hard time switching, hopefully it's not too expensive.
