no pics available
SPECS:
Length: 15' 10"
Beam: 35" 34" (@ 4"Waterline)
Bow Height: 19"
Stern Height: 19"
Center Height:13"
WEIGHT:
Fiberglass 58lbs
Ultralight 48lbs
Custom Kevlar 40lbs
The Scout has an overall length of 15’10" and is one of the most stable canoes in the Clipper line. It can be easily paddled solo when ordered with an optional bench seat in the bow. At a weight of only 58 lbs in fiberglass, the Scout is ideal for portaging and is easy to load on and off your vehicle.
The Scout tracks exceptionally well for a canoe of its length and cruises with an ease reminiscent of much longer canoes. The Scout is great for day tours or short camping trips and for the sportsman requiring excellent stability in a light-weight canoe. It is so light that you can hike it into that remote lake for fly fishing.
The fiberglass layup is stiffened with foam ribs for a lightweight, yet strong, rigid hull. The Ultralight skin coat Kevlar® weighs in at 48 pounds and the Custom Kevlar® at 40 lbs.
