Length: 550 cm / 18'
Width: 96 cm / 38''
Width gunwale: 93 cm / 36.5''
Width waterline: 86 cm / 34''
Depth: 36 cm / 14''
Height bow: 47 cm / 18.5''
Weight: 21 kg / 47 lbs
Capacity: 415 kg / 910 lbs
This big canoe has the same shape as 15 DR and 16.5 DR. With a length of 18 feet, this canoe has a wide and long, flat bottom and tumblehome shape. This makes it exceptionally stable, highly buoyant at the bow and it features a very high load capacity. ALLY 18 DR is mainly a canoe for those who need to carry a lot of gear, in a stable boat. It easily carries 3-4 adults with baggage. ALLY 18 DR is mainly a canoe for plain waters, but its construction makes it perfectly capable on rivers with moderate technical difficulties.
