Length: 558 cm / 18' 4''
Width: 91 cm / 36''
Width gunwale: 88 cm / 34.5''
Width waterline: 84 cm / 33''
Depth: 34 cm / 13.5''
Height bow: 45 cm / 17.5''
Weight: 22,5 kg / 49,5 lbs
Capacity: 425 kg / 935 lbs
This canoe is made for those who need very high load capacity for 3 or 4 persons with baggage. ALLY 18.5 has a good initial and final stability making you feel safe from the beginning. Due to the optimal speed/stability ratio, it tracks faster in the water. The canoe has, like 15.5 and 17, a straight keel line, which gives it superior directional stability. It is the optimal folding canoe for paddling on big lakes and on quiet to slowly moving rivers without technical difficulties.
