Results 1 to 7 of 7
Thread: using a jib
    Hertfordshire
    Default using a jib
    Is it possible to use an old mirror jib as a main sail
    Ought to be sort of possible - its about 20 square feet which is enough to be some use.
    Is it wire luffed or hanked? - and what is the luff length?
    Sprit-boom?
    Marske, 100 metres from the North Sea!
    check my avatar! Picture. David.
    mirror jib, I used 3 inch sections of plastic tube cable tied at each clip point, they slide over the canoe pole mast.
    the top is a 'cup' from a windsurf shop.
    OCSG Graham used a GP14 genoa as a mainsail on his canoe for most of last season and it worked well. He's just upgraded to a Solway Dory 5m rig which he's delighted with but the genoa got him going for minimal outlay.
    Hertfordshire
    Have you got any better photos , did u fit a boom or loose footed and how did it sail
    thanks David
    Hertfordshire
    Its wire luffed will have to check length but it is from an old mirror , sail number in the 3000 and still going
    Hertfordshire
    Like the idea of a Sprit boom ! plus a 20 sq foot sail would suit the boat I am working on
