Results 1 to 26 of 26
Thread: Inflatable sailing canoe
    Hertfordshire
    Lightbulb Inflatable sailing canoe
    I am thinking of building a sailing rig simm to the American , go sailing rigs complete with out riggers for a Sevylor canyon any ideas on the maximum sail size , I have a Mirror rig and a Sea Hopper rig , will it work ????
    The Mirror rig will be too big, even without the jib. The Seahopper would be better as I think it's a bit smaller, though there are different models - which rig do you have? The smallest at 30 sq ft would be good.
    Making something that is stiff enough to hold up the rig on an inflatable will be a challenge. Don't underestimate the forces involved.
    There are very few inflatable sailing boats on the market.
    Two I can think of are:
    1 - The catapult catamaran - this uses an aluminium frame to support the forces.
    2 - The Tinker Tramp/Traveller series - these use a ply frame - rig is about the right size and is "Stayed".
    http://www.tinkerowners.org.uk/p05.htm <<< pictures.
    "Stayed" is debatable in my experience:
    Or maybe the rig heals so the boat doesn't!? I've no idea!
    Hertfordshire
    I think the sea hopper sail is 30 sq f , I am working on having an Ash back bone about 1200mm long with 25mm Ali Out rigger arms and lea board supports , I have had a Tinker Tramp and I am expecting the rig to heal not the boat . I have had lots of large boats of all types and I am know looking for simple and light , with out a trailer.
    Quote Originally Posted by David Harris View Post
    There are a few inflatables on this site.
    www.sailboatstogo.com
    rigged with sails including the inflatable advanced elements . Advanced frame..
    Suffolk
    If I do not sell my Colorado i am going to fix a sail to it, I have a few ideas and will let you know how successful it turns out.
    Oldeng
    Knock on the sky and listen to the sound
    Hertfordshire
    As soon as I start building , poss this week end , I will post some picks for feed back
    I'm looking forwards to seeing how you get on David, it'll be an interesting project.
    Hertfordshire
    Finaly started two Amas 47" by 6 " , just starting on cross beam[IMG] [/IMG]
    Hertfordshire
    The first dry run of the set up , will need to finish main spine and add lea boards , plastic tube will be fitted with epoxy together with all ply supports .[IMG][IMG][/IMG]
    Nice work - very neat and tidy! When I've tried using paddle shafts for anything needing strength/stiffness I've been surprised how much they can bend - can be quite disconcerting. But as you say above, maybe the rig will do the heeling and reduce the pressure on the outriggers.
    That looks really good David. I'm guessing that the gunwales/side tubes of the boat will support the paddle ama spar as well spreading the load somewhat?
    Hertfordshire
    yes ,I am hoping that the 125mm Ash cross bar will take a lot of the strain of the tubes , plus the holes in the cross bar are for lashing's that I hope will fix the paddles and reduce the total span , there fore reducing the paddles bending moment . at the end of the day , its all good fun , if it does not work on the inflatable I can fix it on a ridged .
    Mar 2009
    Worcester
    Made any prgress with this? looking forward to seeing pics of it finished and under sail!
    Hertfordshire
    Should have most of it finished by Sunday , all but a lick of paint , I will try and get some more picks posted with it on the canoe
    Hertfordshire
    [IMG][[IMG][/IMG]
    Finished at last and ready to sail some weeks ago , Bad back is a real pain , will be on water today with a little help from Wife .
    Suffolk
    Hi David
    That looks a good solid setup, will be interested to hear how it sails, best of luck.
    Vic Ward
    Now there completed what would the weight of one be.?
    May 2012
    Surrey UK
    This looks like what I'm after also. Is there any reason for having the mast right at the front ? Also is the sail and mast from another boat or did you make it yourself. Needs a bit of confidence to embark on this much work.
    Quote Originally Posted by GregoireLeGros View Post
    Before you copy this set up, please wait until he has sailed with it in strong winds and it has been proved to work. The mast and leeboard support joints look far too flimsy. They may work in light winds but the leverage of the mast and leeboards can be huge in stronger winds.
    We keep getting asked to fit our rigs to inflatables, but we have not come up with a satisfactory solution yet.
    I've had a play with a sail for my Zpro 300. I hope this link works as I'm still on my hols and wont be able to post pictures properly until I get home.
    https://www.facebook.com/media/set/?...1&l=c07b0a4f92
    Australia
    Im having the same isuws with designing a rig plate for a folding sea kayak to take my sail rigs , Its a big ask , and even with a .8mtr sail the lodings are huge
    Just in case the link I posted didn't work here are the photos of what I've developed. I just need a better steering system and an ability to sail!
    SAM_0083 by chrstphrferg, on Flickr
    SAM_0084 by chrstphrferg, on Flickr
    SAM_0085 by chrstphrferg, on Flickr
    SAM_0086 by chrstphrferg, on Flickr
    SAM_0089 by chrstphrferg, on Flickr
    SAM_0087 by chrstphrferg, on Flickr
    Grabner do some nice looking trimaran sailing rigs that can be fitted to several of their inflatable canoes http://www.grabner-sports.at/SAILS.b..._x.0.html?&L=2. Maximum force 4 they reckon, for the ones fitted to canoes
