Results 1 to 22 of 22
Thread: Hammock Hanging
    Jun 2009
    Bristol
    Default Hammock Hanging
    Firstly, how much sag should I be hanging my hammock with? I hear I'm supposed to sleep accross it diagonally but I have no idea where to start with sag.
    Secondly, if anyone knows of any guides, particularly with pictures for hanging hammocks, tarps and various knots and equipment involved please link it!
    I've searched the forum but I couldn't find anything.
    Amsterdam, Netherlands
    you can find a lot of info here.
    the guy is sometimes over-complicating things in my opinion but the site certainly has a wealth of good suggestions.
    ... or do a search on bcuk.
    re. sag: personally, i have it pretty tight for sleeping in as i like it fairly straight. but you may need to try out different options to find out what you find most comfortable, everyone likes it different.
    Jun 2009
    Bristol
    Quote Originally Posted by lowlander View Post
    Wow, that really is a wealth of information. This guy seems to be deeply involved in hammock science! I'm heading for my first hammock night on friday, so whilst I'm happy with trial and error I don't really want to be adjusting it in the night!
    Also I can't get on BCUK at work, but I'll look at home.
    A BCUK link is here but as Red says, there's a 100 ways to do it. These guys should know link. For the hammock I use "that knot you tie your shoe laces with" after taking a couple of turns round the tree and for the tarp, the evenk/tarp line hitch combo. I'm with lowlander, I like the hammock pretty taught too, I'll induce my own sag!
    linkfest!
    Shropshire
    I use roofrack straps for rigging my hammock now.
    Do a complete turn around the tree (camlock buckle by the tree) then take the long end through a krab in the end of the hammock and back to the buckle.
    They're flat like a tree hugger so wont damage the bark or roll down the tree, very strong and simple to adjust.
    Off topic; I also use them to rig my huge tarp for the same reasons.
    Pieface.
    Jun 2009
    Bristol
    I hadn't thought of that pieface, I was looking for some webbing. Any idea what the breaking strain is?
    Quote Originally Posted by Chainsaw View Post
    aha!
    little stab in the side noted
    Quote Originally Posted by Static View Post
    the site i gave you above has under 'make your own' a formula for calculating the force that's exerted on the hammock supported, incl. ropes or webbing you hang it from. they think a breaking strength of 700lbs should be sufficient.
    i'm not a physicist, however, so can't vouch for it. to hang myself using stuff that didn't come with the hammock itself i use climbing gear which exceeds the above limit by far.
    aha!
    LOL thank goodness, thought you'd missed it
    Shropshire
    No idea. But strong enough.
    Last time i used my hammock the trees were nearly 20' apart and i rigged it tight so quite a lot of strain there.
    Cheers, Pieface.
    Static,
    You donít mention which hammock you are intending to hang in, or whether you are a bed breaker or a featherweight
    I have a DD Travel and slavishly follow their website recommendation here. Interesting to note, it states that the DD Camping Hammock should be tied reasonably tight, whilst the Travel Hammock should almost be tied as tight as possible.
    Hard to figure out the reason for the difference in sag. Obviously whoever tested the prototype of the Travel, must have felt that optimum comfort was achieved when the setup was very taut.
    Apart from the Travel Hammock having an attached bug net, the specs would appear to be identical.
    Looking at the info on the web there are large variations in hangers preferences. I'm still in the experimental stage, but do hope I donít develop into one of those nuisances who are up and down all night making adjustments to the hammock or the tarp rigging.
    Jim
    It is exactly that Jim, the bug net is the difference. As you attach the bug net to the ridgeline or an accessory line any sag will pull it down and if too much sag you could rip it. I use bungees to attach the bug net to the line.
    Another thought, perhaps if the camping hammock was too tight you wouldn't get that roll round effect you want to cover you???
    Jun 2009
    Bristol
    I can't remember the make of the hammock, I got it as a present. When I dig it out later tonight I'll find it.
    I am a bed-breaker though, I'm over 17 stone, probably 17 and half after that buffet I just polished off!
    Stoke-on Trent
    Thumbs up Hammock
    Quote Originally Posted by pieface View Post
    Pieface.
    Hi, I too use one of my Canoe securing straps for Hammocking, have done for quite some time now.
    As you say so simple to adjust.
    Best Regards Bill
    Cheers Alan, Hadn't considered the factor as bug net conservation consideration.
    Jim
    http://www.hammockforums.net/
    All you need is in here. If you join you will find them extremely helpful (if slightly insane).
    Jun 2009
    Bristol
    I'm in the hammock RIGHT NOW! It is megacomfy, I've it a good sag level, we'll see how I feel in the morning though!!
    Instructor at Ember Survival
    Jul 2009
    St. Louis, Missouri USA
    should be about like this...
    Did you survive the night?
    Jun 2009
    Bristol
    Just about! The hammock was comfy, I did feel the cold a bit though and had to hunker down in my bag to be comfy but its not a very thick bag. I could of done with a little less sag but I was limited by the distance between the trees. I definitely need a bug net though
    Nov 2008
    Northern Ireland
    Pieface.
    That's a fantastic idea. Does the camlock take strain ok?
    I'm hoping for my first hammocking weekend next Sat so I'll read all the links and hope for the best!
    Get Outdoors in Northern Ireland
    www.ni-wild.co.uk
    Shropshire
    Jonno, see post #10 above.
    Never had a problem. . . . . yet
    Cheers, Pieface.
