Results 1 to 8 of 8
Thread: screw top barrels
    dunfermline fife
    Default screw top barrels
    Ive got hold of a couple more screw top barrels.
    Free to good home.
    Im in fife but can post for about 7 pounds.
    Soloman.
    It is not that I object to the work, mind you; I like work: it fascinates me. I can sit and look at it for hours.
    Jerome.K.Jerome
    I wouldn't mind one and I think Warthog1981 was looking for one for day trips.
    If you can get hem to Russell I an collect them from him next time I see him.
    dunfermline fife
    Default barrels
    No probs MK.
    Jerome.K.Jerome
    pm sent thanks Steve
    Mid Wales
    Question Barrel seals ?
    Hi Just a small query if I may ?
    I was given a couple of barrels as a gift and have noted that they arent exactly air tight,
    ie, when i squeeze them I can hear the air escaping !
    Should the lids have some sort of rubber seal in them ? there does seem to be a groove where one might fit .
    If so do you think a bead of silicone in the lid might solve the problem ? or can anyone suggest where I might get replacement seals ?
    Thanks noel
    dunfermline fife
    Default barrels
    Hi Noel, yes if they are like the ones i get they should have a white rubber seal inside the lid.
    Pm me the size and ill see if its similar to mine and ill try to get seals for you.
    Soloman.
    Jerome.K.Jerome
    dunfermline fife
    Default barrels
    One left.
    Jerome.K.Jerome
    May 2008
    Co Durham
    Hi, I'll take your last barrel if it's still available.
    pm sent
    thanks
    Mick
    Stay safe, enjoy
