Results 1 to 2 of 2
Thread: Selway Peterborough 14'
    Default Selway Peterborough 14'
    Makers Spec
    Pic's to follow
    Makers Write Up
    This is a 14 version of our larger Peterborough design but in this case we have gone for a design with 7 planks per side. She still uses the simple stitch and tape method of construction and has seats for 2 crew. Midships depth is 12 1/2 (0.32m) and the tumblehome in her topsides makes her both easy to paddle and very stable.
    LOA 14 (4.27m); Beam 32 1/2 (0.83m); Approx. wht 42 lbs (19kg) in 4mm ply.
    Pershore, Worcestershire, UK
    I've just finished building one of these, but stretched the plans to give me a 15 foot canoe. Weight is approx 21Kgs with the bottom 3 planks (per side) in 5mm and the top 4 in 4mm ply and fully sheathed inside and out, but it is hard work to keep the weight this low.
    The build blogg can be found here:
    http://www.songofthepaddle.co.uk/for...rough-15-Build
    Jon.
