Thread: How do I protect my royalex canoe
    Default How do I protect my royalex canoe
    I`ve got a royalex canoe that i want to store on the roof of my narrow boat. I`ve heard that sunlight and heat can affect it, is there anyway that i can protect it?
    303 aerospace protectant is the stuff recommended on some manufacturers websites to block UV.
    I haven't used it myself.
    On very hot days (few and far between on Skye) I put an old sheet over mine. Seems to keep the temperature of the hull down.
    Q
    303 Aerospace rubbed into the hull will protect it. Once every few trips or once per month (more or less) if not in use. It works like sun screen.
    http://www.303products.com/tech/inde...TOKEN=60328413
    http://www.songofthepaddle.co.uk/for...=303+aerospace
    Thumbs up thanks
    Thanks guys thats really helpfrull
    Hamilton, Lanarkshire
    you can get the protectant in the uk from here....
    http://www.thepolishingcompany.com/foryourboat.html
    regards
    james
    Default Thanks for gen on 303
    Thanks for that info on 303 UV protection. I'd been meaning to set up a cover which would hav been difficult without making the garden look like a tip. Already get enough abuse about canoe and kayaks making the garden look a mess. Cheers for the info
    There is nothing—
    absolute nothing—half so much worth
    doing as simply messing about in boats.
