• Strokes
    One of the common misconceptions about using an open canoe is that you paddle on alternate sides. In fact you paddle on one side only in all but rare occasions. The reason you do not end up going round in circles is that each of the strokes has a steering element to it. This is what allows you to paddle the canoe in a straight line whilst powering it on one side only. When paddling tandem the steering element of the stroke is reduced but is still present to an extent.
    The information on the strokes below came from The Canoe Camper site and the animated GIFs were done by Michelle Stacheruk. I am indebted to them for their permission to reproduce this information as it is in my opinion a tremendous teaching aid for those learning the strokes
    There is also an interesting video on paddle strokes HERE
    J Stroke
    This is an animated GIF of the J Stroke as seen from the front of a canoe and from above. This stroke is used to make the canoe go in a straight line when paddling solo. The paddle goes into the water, is pulled back, and turned, like a letter J, at the end of the stroke. .
    Inside Turn with J Stroke
    This stroke is a modification of the J Stroke used to turn towards the paddle side. To increase your turn, start the stroke out from the canoe and draw in towards the canoe before following through with the rest of the J stroke.
    Indian Stroke
    This stroke is also known as the underwater stroke. Some people call it the Canadian stroke, but in fact there's a stroke rather between the J stroke and the Indian stroke that is more generally called the Canadian. The Indian stroke is used for paddling a straight course and is very useful against strong winds or running rapids. As you move the paddle forward, rotate the grip of the paddle in the palm of your upper hand. Then you are ready for the next power stroke without taking the blade out of the water. If you do it slowly and carefully, there is no sound from the paddle, making it possible to sneak up on wildlife and get a close view.
    Box-Stroke Pivot (away from paddle side)
    The Box-Stroke Pivot is used to make a quick turn while the canoe pivots on the pivot point, using the basics, the stern draw and the bow pry. Starting in towards the canoe with a stern draw, you then knife the paddle through the water to the bow of the canoe. Then you continue with a bow pry (pushing the paddle away from the canoe), until the paddle is far enough away from the canoe in order to make another effective stern draw, after knifing the paddle back to the stern of the canoe. To turn towards the paddle side, reverse the direction of the steps and repeat until you are in the desired direction.
    This article was originally published in forum thread: Strokes started by MagiKelly View original post
